Need help picking card option
Go to solution Solved by Castdeath97,
Just now, freedirt said:
I5 3570k
Asus p8 770 vlk
650 corsair
8 gig vengeance mem
Either wait for pascal very soon enough or get this while its cheap:
http://pcpartpicker.com/part/zotac-video-card-zt9050310p
Ok so yea I still play skyrim and I love modding the s%+t out of it, the mods are intense I have a 670 right now and get really low frame so I cant use all the mods I would like too, I play other triple A games as well , I don't want to spend too much maybe under 600 to 500 is there any sli options or single card options in this range Im also going to be playing this on a lg 29uc97c, :'( all I want is butter smooth skyrim or anything kinda close.
https://linustechtips.com/topic/591145-need-help-picking-card-option/
Where are you from?
CPU: i7 5820k @3.2           Motherboard: Asrock x99x Killer           CPU Cooler: Cooler Master Hyper 212 EVO           GPU: Asus 280x DirectCU II
Case: NZXT S340            RAM: 8GB Hyperx Fury DDR4 @2133MHz           HDD: Corsair Force LS 120GB           PSU: EVGA GQ 650W 80+GOLD
3 minutes ago, freedirt said:
TX
What is your CPU?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
1 minute ago, freedirt said:
TX
Hahahah, was more thinking of what country you were from :)
You can get a couple of single cards that will outperform your 670 by miles(they cost less than 500 as well)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127872&cm_re=390x-_-14-127-872-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125696&cm_re=980-_-14-125-696-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150754&cm_re=r9_fury-_-14-150-754-_-Product'
Performance wise the r9 nano is the best performer. The 390x and 980 are almost tied but the 390x is a tad bit better.
You can get a 980Ti at this price now, 980Ti/980/970 prices are dropping ever since the Pascal count down
I5 3570k
Asus p8 770 vlk
650 corsair
8 gig vengeance mem
Uhm, where can you get a 980ti for under 500?
I meant the 500-600 range the OP mentioned, you can get it for 530 though (the AMP! is on a huge discount in Newegg).
530 for the 980ti in an amazing price. If you're comfortable spending that amount, you should go for it OP
We don't know how well Pascal will turn out though its only two days, but by then the discount might be gone. So, it's kinda of a paradox.
Thanks guys I haven't been following the gpu news I need to get my head out of skyrim lol  thanks I'll go grab one of those 980ti before they go back up thanks guys!
If only i had the money to do that :(
Go nuts in mods!
Personally I would wait to see what is Nvidia up to after tomorrow. It might be a good card that you can get, but it might also be something not so great or something mobile. It's a hard decision.
Meanwhile here in the UK that card is still £550 :/
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
UK retailers are oblivious to the potential recent event by Nvidia.
Only cards that seem to be dropping in price are the 980s, seen a few for under £400 now. 960s and 970s seem to be going up and 980Ti's just do whatever they feel like. (I bought my 960 in November for £155, the same card is £190 now :/ My friends MSI 980Ti cost him £510, its now £570 I believe.)
  • Games owned: 62
then you may take a look if you whould buy a  Zotac gtx 980 Ti amp omega through amazon.de 575 euro atm (discount for the next 10 h)
http://www.amazon.de/dp/B011DY6LAY?smid=A3JWKAKR8XB7XF&tag=geizhalspre03-21&linkCode=df0&creative=22498&creativeASIN=B011DY6LAY&childASIN=B011DY6LAY
Still has massive delivery and import tax, wouldnt be worth it
  • Games owned: 62
