48 minutes ago, RADEON_GUY said:
What's your budget? looks like UK is the country
you're going to want neither of those, as they aren't much faster than the A8 APUs, if you just want a basic low power and cheap gaming rig, rather hard to beat something like an A8 7600 or A8 7650K, maybe the A10 7860K if it's cheap
A8 7650K | CS:GO/Dota 2/SC2 benchmarks Tested With 1866Mhz RAM
http://www.technologyx.com/featured/amd-a8-7650k-apu-review-the-little-apu-that-could/4/
A8 7650K | Various AAA titles Tested with 2133Mhz RAM
http://www.anandtech.com/show/9217/the-amd-a8-7650k-apu-review-also-new-testing-methodology/7
https://linustechtips.com/topic/590961-htpc-help/#findComment-7691414
Something simple that I put together, some things may vary depending on your interest/budget/etc
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($111.99 @ SuperBiiz)
CPU Cooler: Noctua NH-L9x65 33.8 CFM CPU Cooler  ($49.99 @ Newegg)
Motherboard: ASRock B150M-ITX Mini ITX LGA1151 Motherboard  ($75.98 @ Newegg)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2400 Memory  ($29.99 @ SuperBiiz)
Storage: A-Data Premier Pro SP900 256GB 2.5" Solid State Drive  ($74.99 @ Amazon)
Case: Lian-Li PC-Q01B Mini ITX Tower Case  ($56.99 @ Newegg)
Power Supply: SeaSonic 350W 80+ Bronze Certified ATX Power Supply  ($43.99 @ SuperBiiz)
Total: $443.92
Generated by PCPartPicker 2016-05-03 17:31 EDT-0400
I hear the integrated graphics on Skylake cpus is actually pretty strong. I if that's the only kind of games your dad plays that should be fine. If you ever want anymore power then that you could pick up something simple like a 750 ti.
I do think it's kind of shit how Intel doesn't include stock heatsinks, even on lower end models so you always have to buy an aftermarket cooler now, even for casual use pcs. I went with the Noctua one there since it was low profile and Noctua makes good coolers.
Motherboard is a simple B150 one. I went with 1 stick of ram since it only has two slots.
Went with a single ssd since that's all your parents will be doing. you can add a hdd if you want more space.
Case I just went with a mini ITX one that wasn't too expensive and looked pretty alright.
As for power supply, just went with a random SeaSonic one, their psus should be good.
Pcpartpicker doesn't show what that motherboard looks like, but here Asrock motherboard
https://linustechtips.com/topic/590961-htpc-help/#findComment-7691431
Just saw he's from UK
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  (£97.26 @ CCL Computers)
CPU Cooler: Noctua NH-L9x65 33.8 CFM CPU Cooler  (£40.45 @ Amazon UK)
Motherboard: ASRock B150M-ITX Mini ITX LGA1151 Motherboard  (£64.99 @ Amazon UK)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2400 Memory  (£28.18 @ Novatech)
Storage: A-Data Premier Pro SP900 256GB 2.5" Solid State Drive  (£69.00 @ Amazon UK)
Case: Lian-Li PC-Q01B Mini ITX Tower Case  (£48.66 @ CCL Computers)
Power Supply: SeaSonic 350W 80+ Bronze Certified ATX Power Supply  (£38.99 @ Overclockers.co.uk)
Total: £387.53
Generated by PCPartPicker 2016-05-03 22:39 BST+0100
https://linustechtips.com/topic/590961-htpc-help/#findComment-7691439
