Posted May 2, 2016 My headset has a crack in its plastic framing and I'm wondering what the best way would be ot fix it? Pictures of the crack are down below. I don't have a lot of money to spend so a nice home-DIY solution would be nice! If anyone is interested it's a Roccat Kave true 5.1 surround sound headset, the first edition, so it's pretty old but I love it to depth so I really want to fix it. As you can see in the picture everything still works, you just can't wear it. Thanks in advance, That13thGuy 01110101 01101100 01100100 00100000 01100100 01101111 00100000 01110011 01110101 01100011 01101000 00100000 01100001 00100000 01110100 01101000 01101001 01101110 01100111 00101110 00101110 00101110 00100000 01010111 01100101 01101100 01101100 00100000 01101000 01100101 01110010 01100101 00100000 01101000 01100001 01110110 01100101 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101111 01101011 01101001 01100101 00100001 Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Gorilla glue? FPS <3 Flick G1 Review Nixeus Revel Review Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683626 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 2 minutes ago, That13thGuy said: ... had the same issue once. glue didnt help very much. maybe duct tape will but i just moved on. Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892 thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen Please quote if you want me to respond and marking as solved is always appreciated. Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683635 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Fixing that is not going to hold. Time for a new headset. Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683642 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Author 1 minute ago, ChrisCross said: had the same issue once. glue didnt help very much. maybe duct tape will but i just moved on. I've tried duc tape allready, but I can't move one man... 01110101 01101100 01100100 00100000 01100100 01101111 00100000 01110011 01110101 01100011 01101000 00100000 01100001 00100000 01110100 01101000 01101001 01101110 01100111 00101110 00101110 00101110 00100000 01010111 01100101 01101100 01101100 00100000 01101000 01100101 01110010 01100101 00100000 01101000 01100001 01110110 01100101 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101111 01101011 01101001 01100101 00100001 Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683647 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Author 1 minute ago, Hans Christian | Teri said: Fixing that is not going to hold. Time for a new headset. *cries deeply* 01110101 01101100 01100100 00100000 01100100 01101111 00100000 01110011 01110101 01100011 01101000 00100000 01100001 00100000 01110100 01101000 01101001 01101110 01100111 00101110 00101110 00101110 00100000 01010111 01100101 01101100 01101100 00100000 01101000 01100101 01110010 01100101 00100000 01101000 01100001 01110110 01100101 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101111 01101011 01101001 01100101 00100001 Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683655 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 1 minute ago, That13thGuy said: *cries deeply* I probably could fix that with some thin metal and some screwes, but yeah... it's time for new headphones Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683666 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 2 minutes ago, That13thGuy said: I've tried duc tape allready, but I can't move one man... thats so cute. i have reserved a special place for my dead/old headphones. they have done they duty, give them some rest. Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892 thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen Please quote if you want me to respond and marking as solved is always appreciated. Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683670 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Author 1 minute ago, Darel321 said: I probably could fix that with some thin metal and some screwes, but yeah... it's time for new headphones gluing the crack shut doesnt work, and duct tape made the head set too loose, but do you think using a small piece of either plastic or metal inbetween the headset and the tape will keep it strong? 01110101 01101100 01100100 00100000 01100100 01101111 00100000 01110011 01110101 01100011 01101000 00100000 01100001 00100000 01110100 01101000 01101001 01101110 01100111 00101110 00101110 00101110 00100000 01010111 01100101 01101100 01101100 00100000 01101000 01100101 01110010 01100101 00100000 01101000 01100001 01110110 01100101 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101111 01101011 01101001 01100101 00100001 Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683688 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 2 part epoxy might work but someone will have to back me up on this. My GTX 970 carries me to global. Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683708 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Author Just now, SpaceTurtle917 said: 2 part epoxy might work but someone will have to back me up on this. I tried that but it just broke of after an hour or so 01110101 01101100 01100100 00100000 01100100 01101111 00100000 01110011 01110101 01100011 01101000 00100000 01100001 00100000 01110100 01101000 01101001 01101110 01100111 00101110 00101110 00101110 00100000 01010111 01100101 01101100 01101100 00100000 01101000 01100101 01110010 01100101 00100000 01101000 01100001 01110110 01100101 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101111 01101011 01101001 01100101 00100001 Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683716 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 7 minutes ago, That13thGuy said: gluing the crack shut doesnt work, and duct tape made the head set too loose, but do you think using a small piece of either plastic or metal inbetween the headset and the tape will keep it strong? hmm. its hard to explain I would make a small piece of metal with 2 holes bend it around the broken piece and on the other side a small screw trough the holes of the metal so it pulls everything together.. I rly should draw it for you edit.. bolt and nut, not screw sry forgot about that Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683724 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Author 1 minute ago, Darel321 said: hmm. its hard to explain I would make a small piece of metal with 2 holes bend it around the broken piece and on the other side a small screw trough the holes of the metal so it pulls everything together.. I rly should draw it for you so the metal wraps around the crack tightly? that could work. One more thing: how about this thing called sugru? It's basically clay that hardens into some form of plastic, it's really cool. Here's a link: https://sugru.com/about . Would that work in my case? 01110101 01101100 01100100 00100000 01100100 01101111 00100000 01110011 01110101 01100011 01101000 00100000 01100001 00100000 01110100 01101000 01101001 01101110 01100111 00101110 00101110 00101110 00100000 01010111 01100101 01101100 01101100 00100000 01101000 01100101 01110010 01100101 00100000 01101000 01100001 01110110 01100101 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101111 01101011 01101001 01100101 00100001 Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683751 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 1 minute ago, That13thGuy said: so the metal wraps around the crack tightly? that could work. One more thing: how about this thing called sugru? It's basically clay that hardens into some form of plastic, it's really cool. Here's a link: https://sugru.com/about . Would that work in my case? ohh yeah... you could try that too.. just fill in the clay and press it together, or even make a ring around it.. but first clean the glue from before Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683775 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Uhh try jet glue. It won't hold forever, but you may get a week or so out of it. If super-glue had a super-glue above it, it would be jet glue. Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683788 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Maybe you should try melting the plastic in that area and just push those 2 pieces together hoping they will become 1 solid piece. Someone once said: "Having a rollercoaster on a PC would be epic" So threw a rollercoaster on my K'nex PC: Project Dragon Khan- K'nex rollercoaster PC build Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683801 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 Those headphones look dead already, might as well just get new headphones. If computers have no doors or fences, who needs Windows and Gates? Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7683846 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 You could try some plastic 'welding'. Not sure what plastic the headset is made of but odds are with a heatgun and some PLA you could make this work. http://f4.network/ http://www.regaleaglerobotics.com/ Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7684080 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2016 3 hours ago, That13thGuy said: so the metal wraps around the crack tightly? that could work. One more thing: how about this thing called sugru? It's basically clay that hardens into some form of plastic, it's really cool. Here's a link: https://sugru.com/about . Would that work in my case? That actually might work. I have some i belive it's called epoxy sculpt. My GTX 970 carries me to global. Link to comment https://linustechtips.com/topic/590330-fix-broke-plastic-headset/#findComment-7684872 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
