So I've tried VLC and MPC and they are okay BUT the quality of DVD playback isn't as good as I'd like which I hope is a fault of the players. I've been looking at ArcSoft Total Media Theatre but it seems kind of sketchy. GF and I have been watching a lot of movies lately. Also anyone else have suggestions for 21:9 playback (native) ?. I bought The Force Awakens on Amazon digital and thought "It SHOULD be available to play in 21:9", but no it didn't, I bought this monitor not just for work but play too :P
System: i7 4790K, Hyper 212 EVO, 16 GB Crucial Ballistix, GTX 1070 Super clocked, MSI Z97S SLI Krait Edition, Corsair RM 750, Corsair 750D (with 2 additional 140mm NZXT fans up top for exhaust.)
https://linustechtips.com/topic/590216-media-player-replacement/
21:9 on Blu-Ray/DVD isn't really supported - the black bars are hardcoded in. You CAN play it in 21:9" on VLC by pressing "C" until you get to "2.35:1".
Are you sure VLC/MPC are the problems? Remember, DVDs are pretty low resolution.
Cyberlink PowerDVD is a terribly clunky solution, but will play back DVD and BluRay at their highest quality and has some Aspect Ratio Control.
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682417
PowerDVD
but I believe the quality issues are with your DVD rather than the player
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682419
yeah It's late :p. I work with video so I should know it's burned that way to be 16:9. Most I've ripped are 720x480 but I've watched DVD's on my parent's TV when they had a 10+ year old DVD player on their 55inch (HDTV) to be specific and they looked great. Just to ensure I wasn't insane I dragged the player over to my 16:9 monitor and it still looked the same :/
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682425
2 hours ago, DXMember said:
PowerDVD
could be, I recall using it before for movies and having no issue, I think it's just the resolution of DVD movies, 720x480 I think. As I grow as a filmmaker and get higer res displays I guess the "blue smoke" of what makes things amazing dissipates.
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682434
How far away were you sitting from the TV? Movies aren't really a close up experience.
I'm not saying its not a player issue, but I've never had any problems with DVD playback quality on any media player on any system in over 10 years so it seems more likely to be a perspective issue on your behalf, or else graphics/monitor/some other hardware issue. But you never know, you might be missing a good codec.
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682440
2 hours ago, themctipers said:
I personally use PowerDVD with my blurays.
would you suggest I go get a Blu-Ray player OR a Blu-Ray drive? I'm still deciding between digital downloads or physical media
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682443
Well, where are you going to play your movies on?
If its a standalone tv, go for the player as a drive won't connect to it.
If you're connecting it to your PC via sata cable, go for the drive because a player is a drive and has software internally to play the movie.
Well it depends for digital downloads or physical media. I like physical media more because I am able to keep it forever and the quality is the best you can get. (blu-ray)
Also, I hate DRM for digital downloads (excluding iTunes, never used it)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682448
I don't mean to think your making assumptions and don't want to come off as rude, I just wanted to clarify.. I'm aware drives use SATA and it won't connect to a TV :p. I'd like the player because ATM GF and I are living with her mom and we only have an 8x10 bedroom so no room for a TV, but I imagine when we get our own place we will have a T.V, plus I do have 2 monitors so I could use my 16:9 for the player.. I was just curious if there was any benefit to one over the other.
https://drive.google.com/open?id=0B_HGP6-H6_CMcHN3MlZpUW5hd2M
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682460
Go for the player as it can play movies without a computer and its universal.
It can connect to your tv or one of your monitors via HDMI.
https://linustechtips.com/topic/590216-media-player-replacement/#findComment-7682490
