I started to build this PC because my current PC and Alienware X51 (Intel Core i5-3330 CPU @ 3.00GHz and NVIDIA GeForce GTX 660) will eventually be taken back my Dads work who I only borrowed it off because it wasn't in use and I would like to have a build ready for a reasonable price to replace it when this does happen preferably under 750€
as I am saving around a year and a half to afford it, the games I currently run are CS:GO and Garrys Mod but I am beginning to move into PC gaming more so I'd like to be able to run games like GTA 5 and Rainbow Six Siege.
I currently use 2 monitors but I don't mind using one and then maybe buying another Graphics Card further down the line after the PC has been built.
Mouse and Keyboard isn't a problem as I already have my own preferred ones.
The build I have picked out in the last few weeks follows and any feed back on how I could improve this would be appreciated. (This is my first build so I might have some components might link wrong that I haven't been able to notice.)
EVGA 600B Bronze 100-B1-0600-KR Power Supply, 600W
http://www.amazon.com/EVGA-Bronze-100-B1-0600-KR-Power-Supply/dp/B00EON40CS?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_image_6&smid=ATVPDKIKX0DER
Corsair Carbide Series SPEC-02 Mid Tower Gaming Case #
http://www.amazon.com/Corsair-Carbide-SPEC-02-Tower-Gaming/dp/B00I0MKMG2?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_image_7&smid=ATVPDKIKX0DER
WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD10EZEX - 2 of these - Preowned
http://www.amazon.com/Blue-Desktop-Hard-Disk-Drive/dp/B0088PUEPK?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_image_5&smid=A2L77EE7U53NWQ
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2)
http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_image_4&smid=A25241C6EWMUO7
Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz DDR3 CL10 DIMM - Black (HX318C10FBK2/16)
http://www.amazon.com/Kingston-HyperX-FURY-2x8GB-1866MHz/dp/B00J8E8Y5C?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_2&smid=ATVPDKIKX0DER
MSI 970 GAMING DDR3 2133 ATX AMD Motherboard - Preowned
http://www.amazon.com/MSI-970-GAMING-DDR3-Motherboard/dp/B00LUY72F6?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_image_9&smid=AR65LILXUWDP0
AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition Processor Preowned
http://www.amazon.com/AMD-FD8350FRHKBOX-FX-8350-8-Core-Processor/dp/B009O7YUF6?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_image_10&smid=A3LS9SSYH8BJ0G
EVGA GeForce GTX 970 4GB GAMING ACX 2.0, 26% Cooler and 36% Quieter Cooling Graphics Card 04G-P4-2972-KR Preowned
http://www.amazon.com/EVGA-GeForce-Quieter-Graphics-04G-P4-2972-KR/dp/B00NVODXME?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_image_11&smid=A2L77EE7U53NWQ
Corsair Air Series AF120-LED Quiet Edition High Airflow LED Fan, 120 mm - Red, Dual Pack
http://www.amazon.com/Corsair-AF120-Quiet-High-Airflow/dp/B00F6S0XJO?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_image_3&smid=ATVPDKIKX0DER
Specified parts are pre owned and others aren't and they total to around 698.54€ American Amazon rather than the 969.55€ from the UK Amazon with nothing pre owned
The main part I'm unsure about is the motherboard as I don't really see the difference in them other than the PCI slots. Please tell me if there is anything I have overlooked in this build.
Thank you for your time. :)
https://linustechtips.com/topic/590114-first-pc-build/
I think you've done a pretty good job.  I would just caution you on the purchase of preowned spinning drives.  If it were a SSD, I'd say go for it, but take caution with the others.
Good luck with the purchase and build!
https://linustechtips.com/topic/590114-first-pc-build/#findComment-7681306
Thank you for the advice, I'll try and be cautious over the 2nd hand parts but it just makes it a lot more affordable rather than buying them brand new
https://linustechtips.com/topic/590114-first-pc-build/#findComment-7681326
I absolutely agree.  There is nothing wrong with second hand parts bud!  I just don't make a habit of buying second hand spinning HDD.  They are just too sensitive to mishandling.  If you can verify the manufacturing date, the drive will more than likely be covered under WD remaining warranty, but that's a bit of a headache to deal with on a fresh build.
https://linustechtips.com/topic/590114-first-pc-build/#findComment-7681341
Try not to go for an AMD build anymore; they aren't good for gaming anymore. See if you can get a skylake or haswell core i5 instead.
https://linustechtips.com/topic/590114-first-pc-build/#findComment-7681352
I would prefer a sky lake but I'll see with what money I've got when buying as amd is cheaper
https://linustechtips.com/topic/590114-first-pc-build/#findComment-7681361
