2 minutes ago, FilipSebik said:
No it won't fit because we need to know your case
Doesn't mean it won't fit. Just means that we can't tell the user that it'll fit in their case. Though when the OP is talking about "fit," they may have been referring to the socket mounting itself.
https://linustechtips.com/topic/589847-liquid-cooler/#findComment-7678575
28 minutes ago, WhiteShadow789 said:
I have the Asus z170p mobo and a i5-6600 and I wanna know if the corsair hydro series h100i GTX will fit and if it is a good cooler.
it will fit in your socket but a bigger problem is wheter or not it will fit in your case
https://linustechtips.com/topic/589847-liquid-cooler/#findComment-7678627
