Hey guys :)
Inspired by Tarans video a few weeks ago, I decided to create a macro keyboard for myself, but instead for premiere, I wanna use it for Photoshop and maybe also Illustrator and Indesign. E.g. Crtl+Alt+Z and Shift+Ctrl+Z as 2 simple forward and backward buttons.
As I certainly don't need a full-sized keyboard, because I wont have so many macros, I was thinking about buying a rather small mechanical keyboard (maybe just a numbpad).
Do you have any suggestions on what I could get, that isn't extremely expensive? It ideally should be under ~70-80€
Thanks for your help :)
Sirious
UI/UX Designer
CPU:
Intel i5 6600k @ 4.4GHz, Noctua NH D-15, GPU: MSI GTX 970, RAM: HyperX Fury 32GB (2x16GB) DDR4, MoBo: AsRock Z170 extreme4 ATX, Storage: 250GB Samsung EVO SSD + 128GB Toshiba M.2 SSD + 1TB WD Blue, PSU: Antec 650W, Fractal Design Define S
https://linustechtips.com/topic/589267-small-mechanical-macro-keyboard/
I was looking for something like this. Found many tenkey keyboards (numpad) from japanese copany like Sawada, Elecom and iBuffalo. It can be easily found for 1000 to 3000 yen in Japan (about 10 to 30 US$).
Might not be super easy to find, but possible : http://www.amazon.de/ELECOM-Tastatur-USB-Anschluss-kompakte-TK-TCM003WH-Japan/dp/B002NEF7Q8?ie=UTF8&keywords=elecom%20keyboard&qid=1461985739&ref_=sr_1_23&sr=8-23
  • 2 weeks later...
Mechanical number pad.
http://www.amazon.com/Filco-Majestouch-TenKeyPad-Numberpad-FKB22MB/dp/B000MGBPNI/
Or a teensy($20) and a DIY plate with a few switches...
Ryzen 7 2700x | MSI B450 Tomahawk | GTX 780 Windforce | 16GB 3200
Dell 3007WFP | 2xDell 2001FP | Logitech G710 | Logitech G710 | Team Wolf Void Ray | Strafe RGB MX Silent
iPhone 8 Plus ZTE Axon 7 | iPad Air 2 | Nvidia Shield Tablet 32gig LTE | Lenovo W700DS
And diodes and wires and Keycaps.
The price adds up fast.
Ssshhh! He doesn't know that yet! You gotta hook 'em before you reel em in!
Yeah. Once you spend the first money, you cant stop to get the rest. Thats where all my money whent. Into my keyboard im building soon once all parts arive
