I've been doing a lot of 3D animation and my render times are outlandishly long. This is due to my current cheap CPU.
I want to shorten my render times. I use Blender for my animations.
The AMD FX-9590 is an 8 core clocked at 4.7 GHz and runs around $280
The Intel i7-5820k is a 6 core clocked at 3.3 GHz and is $370.
Does raw horsepower/cores yield better results or is there something behind the i7 which makes it better for rendering?
My GPU is a R9 285 so I don't know if that could be a factor.
https://linustechtips.com/topic/589014-cpu-differences-for-3d-renders/
What program are you using?
the i7 should be way better because 12 threads and higher single core performance than the fx.
If you are using Blender, a good gpu will cut your render times easily down to 25%
And note, the 8 cores are somewhat fake, because every two cores share some resources
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
its using a much newer architecture with much higher IPC than the fx9590.
Cycles loves cores.
Though the 5820k is probs going to be quicker and as to gpu vs cpu for cycles - depends what you're rendering.
"The wheel?" "No thanks, I'll walk, its more natural" - thus was the beginning of the doom of the Human race.
Cheese monger.
