So I am planning on building my own computer for gaming and video editing, and this is the build I have so far:
My build
The 850w power supply may seem overkill but I am planning on adding SLI for my 980ti sometime in the future. I also want to overclock my cpu and both my gpus that I would have. Would the 850w be enough for a overclock with a noticeable improvement? Or could I get away with a smaller one?
I also plan on adding another monitor later, the same one listed in the build it would be a 1440p monitor instead, (streetguru made some good points). I have all my peripherals besides my keyboard which I plan on buying at a later date as well. My budget for this is no more than $2000.
Edited by ash54
Streetguru made some good suggestions
https://linustechtips.com/topic/588250-overclock-help/
5 minutes ago, ash54 said:
A 980ti would be completely wasted on a 1080p display, so get a better display with a mid range GPU
and you should be going with a 5820K over a 6700K
Dual GPUs isn't going to be worth it either, buy a 4k or 1440p 144hz display before that, could still fit one in here that would be free-sync
This one's a 4k 27" IPS free-sync display, though a 32" or larger 4k display would be better for productivity
http://pcpartpicker.com/part/lg-monitor-27ud68w
This one's 1440p 144hz IPS would be better for gaming at $550
http://pcpartpicker.com/part/acer-monitor-xf270hu
PCPartPicker part list: http://pcpartpicker.com/p/msxmdC
Price breakdown by merchant: http://pcpartpicker.com/p/msxmdC/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.49 @ Amazon)
Motherboard: ASRock X99 Extreme4/3.1 ATX LGA2011-3 Motherboard  ($219.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($54.00 @ Newegg)
Storage: Mushkin ECO3 240GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Storage: Western Digital Red 2TB 3.5" 5400RPM Internal Hard Drive  ($86.99 @ Amazon)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($308.99 @ SuperBiiz)
Case: Cooler Master N400 ATX Mid Tower Case  ($55.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Amazon)
Monitor: Asus PB258Q 60Hz 25.0" Monitor  ($270.98 @ Newegg)
Total: $1536.40
Generated by PCPartPicker 2016-04-27 16:36 EDT-0400
https://linustechtips.com/topic/588250-overclock-help/#findComment-7661450
Total: $1536.40
But if he is going for a 4k display, won't the 390 be to less to run it on 60 fps (games)??
https://linustechtips.com/topic/588250-overclock-help/#findComment-7661478
You'd be running games at 1080p which scales will with 4k, but games likes CS:GO or Dota you could run at 4k.
It's better to buy a high end display before a high end GPU, because GPUs are always changing and new ones come out way more often than display technology.
Right now Polaris/pascal look to launch in june, and the recent rumor going around is that the 490/X is nearly as fast as a 980ti for the same price point at around 300/400, which, who knows, with 14nm AMD is finally on a decently small size
https://linustechtips.com/topic/588250-overclock-help/#findComment-7661500
Okay so I changed the monitor that I would later add to 1440p. I am probably going to get another monitor before I SLI my gpu, but when I game I would only game on one monitor so I still want the 1080p monitor to start out with because I am trying to budget right now. I'm still wondering if the PSU would be good enough to handle a dual 980ti and cpu overclock.
https://linustechtips.com/topic/588250-overclock-help/#findComment-7661544
