I've had my current setup from september last year, so both the Hard drive(Western Digital 2TB Green) and the power supply (EVGA Supernova G2 850w) aren't a year old yet.
Today for some reason some time after booting(usually 10-15m) my PC my Hard drive(which is the secondary after my SSD) will dissapear without a trace, if I was playing any game from it my PC will hard crash with a blue screen.
I haven't installed anything recently.
I have replaced the SATA cables and it hasn't helped, I need advice on this.
https://linustechtips.com/topic/588210-secondary-hd-issue/
hey try replugging then again hard drive are not very reliable
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660662
Booting takes 15 mins????
Is your OS on the WD green?
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660667
No, the 15minutes are referring to the time it takes for the hard drive to dissapear
2 minutes ago, Moonzy said:
try a different sata port
and try checking "create and format disk partitions" in windows to see if it detects it
I'll try and change the port, and it doesn't unless I restart but it disapears after 15m, during that time I can access my files and everything on my HDD without any problems
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660677
download crystal disk info, see what it says about that drive
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660699
6 hours ago, yoggie123 said:
15 min is good my takes 45 min
You need one of dem SSDs man....
Checked your SATA cable? Check close to the connector if there are wires springing out
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660741
1 minute ago, yoggie123 said:
i do have one its 250 gbs i store all my games there and one my 3tb hd i have windows
Loading time vs booting time ..fight!
Booting time wins..especially if its as ridiculous as 45 mins (unless you're trolling all along; then hats off )
Switch the OS over to the SSD? I have a 20yr old system with XP on a pentium 4 and a Maxtor (!) which boots faster....
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660811
yea but i hate when deep sea hunter 2 takes forever to load
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660831
move that alone to the boot drive then
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660855
3 minutes ago, Moonzy said:
if its under warranty, send it in immediately
Sigh, first time something broke so quickly wasn't expecting this at all.
Not sure what to do though, I have 1.5TB of data there with no means of doing a backup unless I buy a new HDD.....which feels like beating the point
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660883
what about deep sea diver 1 and elder scrolls 1
Look your SSD is 240 gigs...manage the space in that well ..or just spend 30 dollars for an Adata SSD (120gig) .
You werent kidding about the 45 min booting time?
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660888
no i wast and my pc is about 2350 i got it on cyberpower pc
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660895
Other specs? OS?
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660899
i suggest you purchase a 2nd 2TB drive and back it up
then send your drives in, there's no other way to retain your data AFAIK
unless your warranty covers it
please watch this before you take action
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660903
or maybe you can ask @Captain_WD whats the best action to take...
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660919
Other specs? OS?
gtx 980ti
razer case idk which but its green and i like it
i7 5830k
hyper 212 evo with green side fans things
15 boost overclocking
windows 10 pro
250gb ssd samsung
3tb storage
i got this 250 dollar motherboard they said its good
and 300mbps internet
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660922
gtx 980ti
i7 5830k
windows 10 pro
250gb ssd samsung
3tb storage
Lead me through a merry chase...nice trolling mate.
Whats the make of the HDD?
https://linustechtips.com/topic/588210-secondary-hd-issue/#findComment-7660942
