Just now, Tedster said:
Have you zoomed that clip at all? It seems like it's zooming in the export but not in the preview?
Are you exporting a different aspect ratio without scaling?
The first clip in the video is 1080p and the rest are 4k I'm using CS6.
All of the 4k clips are screwed.
https://linustechtips.com/topic/587921-video-editing-problem/#findComment-7657336
What definition of 4k?
The 4096x2160 or the 3840x2160?
Because if the former, that's probably your problem, being slightly shorter than 16:9.
Sig under construction.
https://linustechtips.com/topic/587921-video-editing-problem/#findComment-7657343
Where it says FIT on the left side of the preview window...
Make that 20-50%, then double click the frames, it should now be highlighted so you can properly stretch it to the borders.
Alternatively.
Locate this drop down box and try the other options (AKA Stretch to Fill)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/587921-video-editing-problem/#findComment-7657382
Alternatively.
Doesn't affect it.
https://linustechtips.com/topic/587921-video-editing-problem/#findComment-7657405
3 minutes ago, Valhalla said:
Okay will do thanks
Added more to my post above.
But here it is again
https://linustechtips.com/topic/587921-video-editing-problem/#findComment-7657410
https://gyazo.com/f542f9f039f8aa4b06c2b3f6a5407119
changing that to 50 if its 4k vs 1080p?
https://linustechtips.com/topic/587921-video-editing-problem/#findComment-7657472
2 minutes ago, Valhalla said:
Nah the main program window, before exporting.
https://linustechtips.com/topic/587921-video-editing-problem/#findComment-7657480
I dont know how to get there. Litterally new to this. I guess I'll try to set all of these to 50% https://gyazo.com/f542f9f039f8aa4b06c2b3f6a5407119
Also it says 960x540.
Does that mean its going to be in that res?
https://linustechtips.com/topic/587921-video-editing-problem/#findComment-7657487
