maybe going with an i5 6500 instead of 6600, since its just 100mhz more for a lot more pricier
and a hyper 212 will do the job
and maybe buy a case fan or two (iirc s340 only comes with two) for 2 intake 1 exhaust, which will be optimal
other than that, no problem
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/587785-first-build-need-advice/#findComment-7655810
At a quick glance the first thing I noticed is that the mouse you selected is an older, discounted mouse. The new model of the mouse is much more expensive and would have you opt for the g303 mouse instead which is about the same price with out the 12 button layout.
Also, you might as well get the K series processor.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/587785-first-build-need-advice/#findComment-7655812
10 minutes ago, edwar5jm said:
Should get an i7 6700 with a free-sync 1080p 144hz display man
PCPartPicker part list: http://pcpartpicker.com/p/M2Xpxr
Price breakdown by merchant: http://pcpartpicker.com/p/M2Xpxr/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($301.99 @ SuperBiiz)
Motherboard: MSI B150M Pro-VD Micro ATX LGA1151 Motherboard  ($59.99 @ Micro Center)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($54.00 @ Newegg)
Storage: Mushkin ECO3 240GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ Micro Center)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($317.00 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.95 @ Amazon)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Monitor: AOC G2460PF 144Hz 24.0" Monitor  ($261.98 @ Newegg)
Total: $1216.88
Generated by PCPartPicker 2016-04-26 17:05 EDT-0400
https://linustechtips.com/topic/587785-first-build-need-advice/#findComment-7655836
12 minutes ago, edwar5jm said:
this is my first build, have a parts list and want to get any final opinions or thoughts before i purchase
also wondering if im missing anything, case fans, wires, hardware, etc.
anything is appreciated
http://pcpartpicker.com/p/Xzq9qs    (budget $1500)
If you could spend another $50-$100 over your budget, go with this (http://pcpartpicker.com/p/gY3MGX).
If not then check out the following.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.49 @ Amazon)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($38.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.88 @ OutletPC)
Video Card: Gigabyte Radeon R9 390 8GB Video Card  ($299.99 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($63.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($95.25 @ Amazon)
Monitor: Acer GN246HL 144Hz 24.0" Monitor  ($197.98 @ Directron)
Keyboard: Cooler Master Storm QuickFire Rapid Wired Gaming Keyboard  ($75.99 @ Mac Mall)
Mouse: Logitech G502 Wired Optical Mouse  ($49.99 @ Best Buy)
Total: $1233.52
Generated by PCPartPicker 2016-04-26 17:08 EDT-0400
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/587785-first-build-need-advice/#findComment-7655859
