I noticed that my AF120 fans (3) on the top of the case make a lot more noise when the dust filter is on. When I remove it, I notice decreased noise and much more airflow to the hand. Should I get static pressure fans for the top, im getting watercooling parts soon anyways so can I invest into the 3rd empty spot?
Case: Corsair 780T
https://linustechtips.com/topic/587428-sp-fans-for-case/
well, if you're getting new fans, i suggest
NF-F12/silent wings 2
but if you wanna stay with corsair, get their silent edition SP fans
also, you can try lowering the rpm of the AF fans you have, see how it goes
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/587428-sp-fans-for-case/#findComment-7652120
I always lower the fan speed in normal use with the fan controller, of course its silent then but very minimal airflow
https://linustechtips.com/topic/587428-sp-fans-for-case/#findComment-7652136
well its a tradeoff between silence and slight increase in temps then
if your temps are fine with the fans spinning slower then i wouldnt bother spending money swapping them tbh
but if you're going to watercool then maybe you can invest in an SP fan or two, but i recommend NF-F12 over corsair fans
https://linustechtips.com/topic/587428-sp-fans-for-case/#findComment-7652143
