Hi guys, so basically im getting a new gpu that is a gtx960. but i have a very terrible power supply that has enaugh wattage but i dont think enaugh amperage on the 12v rail. The psu is codegen qori 550w i will link a photo of its specs :1_1_18198257.jpg
So will i be able to run the gtx960 full load without any problems? btw i have an i5 4440 and an asus h81m-k mobo
ty guys
https://linustechtips.com/topic/587121-gtx960-power-requirements/
That's plenty of room. Not sure how reliable is that PSU though.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
ty guys
@STRMfrmXMN This a bad grey unit?
500-600 watt should be more than enough for your new video card
If you are on a tight budget this should do well for you:
 http://www.amazon.com/EVGA-BRONZE-Continuous-Warranty-100-B1-0500-KR/dp/B00DZ6R9GE/ref=sr_1_1?ie=UTF8&qid=1461595109&sr=8-1&keywords=evga+500watt+bronze
Photography / Finance / Gaming
ty guys
DO NOT USE THAT. The +12V rails can only output around 230W - and that's split unevenly - you are HIGHLY likely to burn out the system
17 minutes ago, Kaspar said:
Damn :D i go on one forum people say it will burn my house. I go on here and you people really calmed me down. Welp i guess i will have to go and see. Anyway im still waiting for replies to see more opinions
Don't use it man, the others are right....
19 minutes ago, Paralectic said:
It will definitely work fine, I've had bullshit crappy ass chinese PSUs on *60 cards without any issues.
That PSU has less than 150W for the GPU total
22 minutes ago, Starelementpoke said:
We just refer to no name/unknown brand PSUs, similar to the ones you find in pre-builts, as grey units. At least I do.
8A on the +12V1 and 14A on +12V2 - dangerous as fuck
That is in no way a 550W PSU - it's more like 300W at best
That's the thing, if it was rated from a reliable brand, then yes- I'd go for it.
But it's not and looking at the power listings it won't even be able to power a 950 fully without danger. The OP is running a VERY high risk
See the thing is 960 is already ordered and i have no way of knowing what to do now
Either order a new PSU or return the 960.
but are you sure i wouldnt be able to run it? my cpu isnt the most hungry one either.
A system without a GPU uses around 100-120W. The 960 uses 120W at stock and 140W in the real world due to GPU Boost 2.0
Your PSU can provide around 230W before giving in. 230 < 240
Only 96watts on the V1 rail? Totally reliable, much safe.
1 minute ago, xAcid9 said:
Only 96watts on the V1 rail? Totally reliable.
Best Fire cracker NA :D
2 hours ago, Kaspar said:
oh never knew that :D i just refer to them as sh*t
Well your PSU appears to be shit :PI'd replace it with something in yellow in my signature.
