Help me ?
Solved by SeanFarmer,
1 minute ago, Moonzy said:its normal for gpu to be pinned at max, its bad if it isnt
anyway in that case, try uninstalling the current driver using DDU, and install an older driver like 361.xx or 362.xx, 361.91 for example
remember to download the version for the right operating system you're using
okay awsome thanks guys
Featured Topics
atxcyclist ·
Posted in Home Theater Equipment0 -
3
ElChales ·
Posted in New Builds and Planning4 -
Gundmi ·
Posted in Troubleshooting0 -
ElChales ·
naldo29 ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
