check the CPU temp in the BIOS and report back......could be a bad cooler/TIM application.....have you installed windows yet....
we need more info other than your specs!
any one of you parts could be the problem
start with a BIOS reset, 1 stick of ram and a onbord video if you have it. Also if you have old parts that you know work try swapping things out for things know to be in GOOD working order.
