Hello i need help and recommendation about pc build for photoshop editting video etc. Mainly for image edtting and web developing. Can you help recommend a pc build that will not lag. I have $3600 for the pc excluding monitor and pheriperals. Thanks
Winners never quit, Quitter never win
https://linustechtips.com/topic/585488-need-help-multimedia-photo-editting-pc/
You can do this for under 1500 easy. Under 1000 if you had to even.
Will you be playing any games?
Do you really want to spend all your budget even if you won't see any performance increase in those tasks you mentioned?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
Well you don't need to spend anywhere near that if that's a US based build
Are you doing any gaming?
Here optimized for silence with a workstation GPU just cuz although it does have 4 display port outputs and will be low power and optimized for your workflow most likely, and a 950 NVME SSD that'll be really fast, just double check that the M.2 on the board is PCI-e it should be anyways
Spend the rest of your money on a 4k display array or something, or a professional 4k display with 100% adobe RGB that's 32"+
PCPartPicker part list: http://pcpartpicker.com/p/nRhjYJ
Price breakdown by merchant: http://pcpartpicker.com/p/nRhjYJ/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($301.99 @ SuperBiiz)
CPU Cooler: Noctua NH-L12 37.8 CFM CPU Cooler  ($59.69 @ Newegg)
Motherboard: Asus B150I PRO GAMING/WIFI/AURA Mini ITX LGA1151 Motherboard  ($122.99 @ SuperBiiz)
Memory: G.Skill Aegis 32GB (2 x 16GB) DDR4-2400 Memory  ($105.30 @ Newegg)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($316.09 @ Amazon)
Storage: Hitachi Deskstar NAS 4TB 3.5" 7200RPM Internal Hard Drive  ($159.88 @ OutletPC)
Video Card: ATI FirePro W4100 2GB Video Card  ($159.99 @ Newegg)
Case: Cooler Master Silencio 352 MicroATX Mini Tower Case  ($59.99 @ Mac Mall)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $1355.91
Generated by PCPartPicker 2016-04-21 22:40 EDT-0400
Yep i play dota2 also but mainly build for multimedia works. Maybe i'll consider about the display or any recommendation?
Total: $1355.91
Thank you. Is gtx 980ti bad for multimedia works? And any recommendation on the display?
No, but it's entirely pointless for your workload lol, if you want to do gaming anyways and you mostly play dota 2 go for a 390, and a 1080p 144hz Free-sync display for your gaming display. and then still buy the high end large 4k display for productivity
390
https://pcpartpicker.com/part/powercolor-video-card-axr93908gbd5ppdhe
1080p 144hz TN free-sync $269
https://pcpartpicker.com/part/aoc-monitor-g2460pf
1440p 144hz IPS Free-sync $550 A nicer display naturally
https://pcpartpicker.com/part/acer-monitor-xf270hu
390
sorry for the late response.
maybe my last question is which is better, 390 or GTX980.
Thanks a lot
Thanks a lot
Different price brackets, but the 390 is going to be of better value, the Fury(non X) is the one that beats out the 980
But the 390 will be fine for 1440p gaming at medium-high settings, plus current Nvidia cards don't really support DX12 too well, while AMD cards can gain up to 20% more performance in the best case scenario. In the recent hitman game a 390 is reportedly beating a 980ti under DX12
and a G-sync display is going to run you more, usually by enough that would have gotten you a better AMD GPU with the same display specs
390, more wins at 1440p + though
http://www.tomshardware.com/reviews/sapphire-nitro-r9-390-8g-d5,4245.html
http://www.eurogamer.net/articles/digitalfoundry-2015-amd-radeon-r9-390-8gb-review
Fury v 980
http://www.extremetech.com/extreme/209665-amd-radeon-r9-fury-review-chasing-the-gtx-980s-sweet-spot/2
http://arstechnica.com/gadgets/2015/07/the-r9-fury-is-amds-best-card-in-years-but-just-who-is-it-for/
http://www.pcworld.com/article/2946532/radeon-r9-fury-review-the-fury-xs-little-brother-is-amds-geforce-gtx-980-slayer.html?page=2
