3 minutes ago, WannaBeeComputerGeek said:
I watch a video tutorial about using flash drives in a raid 0 i want to learn how to use different kinds of raid using flash drive in windows
Creating a RAID array with flash drives is a HORRIBLE idea. Since they can fail easily and are not designed for the strain of being in an array. Either way, you can create an array by going to "Create and Format Hard Disk Partitions" in windows.
My native language is C++
https://linustechtips.com/topic/585472-raid-using-flash-drive/#findComment-7633154
i tried this a while back, aiming for raid 0 as to keep some data as "missile keys" between me and a friend. ITS A RABBIT HOLE OF SELF INFLICTED FRUSTRATION WITH LITTLE REWARD
maybe in linux or OSX or with some small external hdds
Aside from saying "I did it" there really aren't any practical uses
If you want raid 1 just set task to clone or copy data
if you want 0 just buy a usb3.0 since software raid with the speeds of thumb drives and the ghetto rigging needed isnt really that fast
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/585472-raid-using-flash-drive/#findComment-7633189
