Need help with infected PC
Solved by icey,
2 hours ago, ErnyNet said:Malware auto installing stuff , lots of it
That usually means either 1 of 2 things.
1. You're downloading free software bundled with adware, and you're failing to select the appropriate boxes OR
2. You're downloading dodgy programs that bundle adware without giving you the option of not installing them.
I recommend Hitman Pro to scan your system, uses definitions from all AV's.
Also for active protection ESET Smart Security. I'm a reseller, I'd be happy to help you out.
