Umm, what are you calling DSL?
DSL is for Digital Subscriber Line and most people now use ADSL (asyncronous), or VDSL (fibre either to the home or to the cabinet)
So, don't understand what you are trying to say when you say your mothervboard has no network adaptor... it must have either an ethernet or PCI adaptor or USB adaptor to get internet onto the unit.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/585247-dsl-connection-issues/#findComment-7630968
I think they're meaning ethernet, and the 'network adapter' as Wi-Fi.
6 minutes ago, Ruled said:
So I have built a new gaming pc with win 10 and I have yet to pick up Internet on it. I have to use DSL as my mobo has no network adapter. I have put my DSL into my mobo and the pc still does not pick it up. Does anyone know any reasons for this
Are you sure the cable works, and that it's plugged into the right port on each end, if that's indeed what you mean?
If you're going through switches, make sure they are all being powered properly.
Sig under construction.
https://linustechtips.com/topic/585247-dsl-connection-issues/#findComment-7630977
Sorry I meant Ethernet and this ethernet cable works fine on other pcs but it shows orange lights on this one. I have it in the right port but how do I check if the port is being powered properly
https://linustechtips.com/topic/585247-dsl-connection-issues/#findComment-7630991
https://linustechtips.com/topic/585247-dsl-connection-issues/#findComment-7630993
Showing orange lights? That sounds to me that it's trying to communicate. Sounds fine.
You can be sure that the port on the switch/router is powered if you're able to use that port with other machines successfully.
I think the problem you're facing is that you need to install network drivers before you can connect to the network at all. I'd suggest using another computer to download the latest network drivers for the board to a memory stick, copying them across to the new computer, then install and see if it helps you out any.
https://linustechtips.com/topic/585247-dsl-connection-issues/#findComment-7631001
Ok so I'm going into my old pc to download network drivers to install onto this pc?
https://linustechtips.com/topic/585247-dsl-connection-issues/#findComment-7631026
As @Tedster said above, you are very well in the position that you don't have drivers you need. I would suggest going onto the motherboard manufacturers website, finding your exact board and downloading all the drivers for windows 10 version and putting them onto a USB drive of some sort and then going onto your new PC and installing the drivers from there. You may have to use a USB 2.0 port as sometimes the drivers for USB 3.0 aren't present either... but give it a try first if you like, then if you run into problems, try a USB 2.0 port.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/585247-dsl-connection-issues/#findComment-7631036
