3 minutes ago, MARK-dam said:
the power supply cover blocks most of the second 140mm fan
is that normal?
http://prntscr.com/audne4
http://prntscr.com/audl6r
can that affect the airflow?
looks like the bottom fan is split. but half is going to the PSU and hdd bays under the shroud, and the other half is going up.
On 4/21/2016 at 4:24 PM, Aytex said:
It is normal but yea it will affect airflow, as long as you have one in the back as exhaust you should be good for airflow
On 4/21/2016 at 4:25 PM, Moonzy said:
it's normal and its fine
it will affect the air flow but not so much that you'd have to worry bout it
is it good to keep the air going to my gpu (gigabyte gtx 970 g1)
from my experience with psu shroud, most of the air will go up into the gpu compartment anyway
since the bottom is almost a dead end, unless your psu is faced up drawing air
-sigh- feeling like I'm being too negative lately
