Plantronics RIG Surround?
Go to solution Solved by spwath,
Nope, cloud is much better.
Spec Page
Thoughts? Here in PH, it's the same price as a Cloud I.
The USB thingamajig looks interesting.
The 7.1 surround is software-based though so no point including that in the "value" of the product.
Karamo
CPU: AMD Ryzen™ 5 3600 | CPU Cooler: Wraith Stealth | GPU: Gigabgyte AORUS GeForce RTX 2070 Super | Motherboard: MSI B450M Mortar Max | RAM: G.Skill FlareX 2x8GB 3200MHz CL16 | SSD: ADATA XPG SX6000 Pro M.2 256GB | HDD: 1TB 2.5" Western Digital Blue (WD10SPZX) | Case: NZXT H510 | OS: Windows 10 Pro 64-bit |
https://linustechtips.com/topic/585070-plantronics-rig-surround/
https://linustechtips.com/topic/585070-plantronics-rig-surround/#findComment-7629503
NO just NO, get the cloud I, they are much better.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/585070-plantronics-rig-surround/#findComment-7629516
Noted
Karamo
https://linustechtips.com/topic/585070-plantronics-rig-surround/#findComment-7646881
I own these. If you're looking for a mixer like the one included in the RIG, or if you're planning on using some other device to play music alongside(or if you want to answer phone calls) while playing, then it's nice. I've used several gaming headsets, various closed/open headphones, IEMs, powered desktop speakers, expensive car audio, etc. As far as sound quality goes, the presentation of sound is decent. I haven't tested these to find an actual frequency response curve, but they work well with both games and music. My biggest issue is that the microphone level is unbelievably low. If you're playing on a console, these will be just about unusable unless you're the kind of person who really yells in-game. On PC, with AGC enabled, this isn't an issue, and the microphone sounds fine.
They're both definitely entry level items, and if you aren't looking for the USB dongle's specific features, you might as well get the HyperX.
https://linustechtips.com/topic/585070-plantronics-rig-surround/#findComment-7647699
yep that's what got me interested in the first place ahahaha
but it looks like im going with the HyperX. If only you can buy the dongle separately ahahahahahaahaha
Karamo
https://linustechtips.com/topic/585070-plantronics-rig-surround/#findComment-7658324
