23 minutes ago, Vishal Gupta said:
MINIMUM REQUIREMENTS:-
-AN SSD(ABOVE 64GB)
-HDD(ABOVE 200GB)
-4TH GEN i3, I5 OR I7
-AT LEAST WINDOWS 7
-MINIMUM 6GB RAM
-LAN ENABLED
http://www.amazon.com/HP-Convertible-Touchscreen-Processor-Bluetooth/dp/B0197IJX9O/ref=sr_1_16?s=pc&ie=UTF8&qid=1461147652&sr=1-16
Get
your own 1TB SSD and you're still under budget.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/584639-help-with-laptop-buying/#findComment-7624457
or what you could do, is go to websites like xoticpc and ibuypower and configure your own laptop.
Eg- http://www.xoticpc.com/msi-cx62-6qd-047us.html
The base configuration has everything you need except the SSD, which you can add while customizing the laptop.
Why this? Cause better bang for the buck.
https://linustechtips.com/topic/584639-help-with-laptop-buying/#findComment-7624890
