I need a new case please help
Go to solution Solved by Steel_Wind,
See also the NZXT 440 along with the aforementioned Define R5.
If you are gong to 280mm cooling support in a white case, you limit your options significantly.
Hi, I know I am going to get so much hate for this but I forgot to check to see if my AIO CPU cooler will fit in my case and now I have bought a 280mm radiator with a case that can only support a 240mm rad. I need to buy a new case because I don't want to get rid of the cooler. I need something that is cheap, white, has a side window, and can support a fan controller in the front. oh and my motherboard is an ATX, I have an ATX power supply, and my graphics card lenght is 312mm. I am really in need of this and I need something as cheap as possible. I was thinking about This but I need to know if there are any other solutions that may be cheaper or better for the same price, I am really on a budget here. Thank you guys so much.
https://linustechtips.com/topic/584289-i-need-a-new-case-please-help/
