What is the easiest way in creating a border around a picture object that is 7 wide on each side.
Without repeating this 28 times:
for a in range(getWidth(picture)):
setColor(getPixel(picture, a, 0), blue)
or this 4 times
    w = getWidth(pic)
    col=0
    while col<w:
        row=0
        while row<7:
            pixel = getPixel(pic,col,row)
            setColor(pixel,red)
            row=row+1
        col=col+1
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/583568-python-help/
I'd guess the best thing to do is just define a function that does that, and then call it later to save re-typing out the code:
def make_border(pic):
    for a in range(getWidth(pic)):
        setColor(getPixel(pic, a, 0), blue)
But without knowing anything about what you're doing, I don't know if there might be a better way to go about it.  Just defining a function you can call later is definitely a good place to start though, based on what you've given.
https://linustechtips.com/topic/583568-python-help/#findComment-7613927
