2 minutes ago, Mark77 said:
Can you go with a 240gb SSD and delete the 1Tb hard drive, at least initially?
I'd even tell you to go onto eBay and pick up a $60 240gb Intel 520 SSD used, rather than a 120gb model.
I'm just planning on using the ssd for Windows so it'll boot up faster, but I could do what you said
https://linustechtips.com/topic/583470-need-help/#findComment-7612848
The problem with the 120gb size nowadays is that there are so few chips (ie: R/W channels) on them that they are dramatically slower than their higher-capacity cousins, or even previous models that used less dense chips.
https://linustechtips.com/topic/583470-need-help/#findComment-7612851
4 minutes ago, Zeinone said:
Maybe switch from the 970 to a R9 390, and perhaps u could replace the RMx PSU with the EVGA SuperNOVA G2 650W one and save a few bucks and still having a top quality PSU
I'd much rather go with nvidia and corsair for parts that I can, thanks for the input though
https://linustechtips.com/topic/583470-need-help/#findComment-7612874
I guess your right, maybe upgrade it to a 240gb and keep the 1tb?
https://linustechtips.com/topic/583470-need-help/#findComment-7612880
