So I am drawing a sketch in my sketchbook, and it's supposed to have the theme 'start to finish' to it. So me being a car guy, I thought I'd draw a 'car' where one end is the concept sketch, then it goes to the clay model, then it goes to a chassis, and then the finished car on the other end.
I did some Googling but I could barely find concept sketches for actual cars, much less a side view of a clay model and bare frame and stuff. So I need some help sourcing some images to work off of. I will be using photo references to make a drawing, probably with colored pencil.
To give you a better idea:
I might make it a hard transition to the next stage or a sort of gradient or something, but that will happen as I start drawing it. I was thinking of a 2015 Ford Mustang, but if you guys have another car in mind and can find the pictures I need then go for it. Just keep in mind I'm not a Chevy/GM guy.
Thanks!
https://linustechtips.com/topic/583425-need-help-finding-a-image-or-two/
Just now, Supercian411 said:
looks cool. if the edges were trancitions were sharp and clean that would look great
Yeah I just need help finding the right images... I'm looking at the new Ford GT as well, but sketches for this car are hard to find too.
im looking aswell and all i founs was multiple sketches of a concept for 2020
also somthing non-tech realted what endeged animals do you like as im making a hat for textiles (it will be made of fleece not animal skin)
Okay, so far I've found these:
So now I just need the frame or something and then of course a final picture of the car which is this:
So last picture I need is some sort of 'frame' picture. Something with bare metal...
Ugh, idk to be honest. Isn't the Siberian Tiger endangered or something?
not sure if that will help
No it needs to be a side profile, just take a look at my last post with pictures in it, I just need a side view of that car with like bare metal and stuff or a pre-production test model or something.
