Airflow Help
Go to solution Solved by Senzelian,
Just now, Artemis67 said:
indeed i do my good sir all have filters on them!
Then you're good to go. :)
Have fun enjoying an almost dust-free pc :P
Hello everyone, just have  quick question related to airflow.
I am trying to achieve a positive pressure environment. My case is an NZXT switch 810
I have an H110 in the top in push pull as intake with a 3rd 140 intaking as well
2 front  140s as intake
and 1 140mm exaust
but 2 gtz 780 ref cards which i believe are blower style
I have all my fans at 1200 rpm they all noctuas so theyre stupid quiet.
Ive also removed the drive bays as they were not being used for less restriction.
and yes i have filters on all my intakes
Just wondering if the picture i attached is an optimal setup or if i should swap my rad to be exaust.
Thanks for your time :)
Cheers!
https://linustechtips.com/topic/583418-airflow-help/
4 minutes ago, Senzelian said:
Looks good.
I hope you have dust filters for the top of your case, cause otherwise the whole "positive air pressure thing" is useless. ;)
i believe they are the silverstone 140 fine mesh ones
cant quite remember brand not that it really matters
https://linustechtips.com/topic/583418-airflow-help/#findComment-7612374
