Help with budget build
Go to solution Solved by Castdeath97,
Just now, Windows10Home said:
EVGA GTX 950 FTW
Intel i5 4460
ASUS Z97-P
Hyperx Fury DDR3 2x4GB
Corsair CX450M
Corsair Carbide SPEC-01
Seagate SSHD 1TB
Windows 10
Get a i5 6400 and a B150/H170 board. 2*4GB DDR4 RAM and drop the SSHD for a normal hard drive since your budget is already limited. See if you can afford a R9 380 4GB.
I need help with a budget build!
My budget is around 8000NOK including Windows 10 USB
Here is the website im going to buy from: www.komplett.no
The best I have come up to is a GTX 950 and an i5 4460
Going to use it for gaming
Windstriker 1.0
CPU: Intel Core i5 6600K
CPU Cooler: NZXT Kraken X61
Motherboard: ASUS Z170-A
Memory: Crucial BallistiX Sport LT DDR4 2400MHz 16gb (2x8GB)
GPU 1: XFX HD 7970 3GB Double Dissipation
GPU 2: Gigabyte HD 7970 3GB Windforce
SSD: HyperX Fury 120GB
HDD: Seagate Barracuda 1TB 7200RPM
Case: Fractal Design Define S
PSU: EVGA SuperNOVA 850 G2
Old Laptop
CPU: Intel Core i3 3110M
IGPU: Intel HD Graphics 4000
Memory: No-Name DDR3 4GB (1x4GB)
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/
1-Why not skylake?
2-Can you show a list of the parts you managed to come up with along with the 950 and i5 4460.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609011
i wish there's an english version of the website `-` but ill try my best to navigate through it
hmm
this build is (cough) okay (cough)
https://www.komplett.no/product/793073/datautstyr/pc-i-deleroppgradering/pc-i-deler-intel/pc-i-deler-core-i5-6600k-gtx960
comments:
1) good case, thats a really good PC case
2) BAAAAAAAAAAD power supply, dont overclock on it (i recomment the EVGA GS 550W)
3) decent cpu, motherboard, ram and gpu choices
4) BAAAAAAD SSD (i recommend the 850 evo)
5) meh dvd read/writer
6) bad cooler if you plan to overclock
all in all its a good package, some stuffs i would tweak about it though
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609018
hmm
comments:
  Reveal hidden contents
It dos not include Windows, so that's a bummer
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609022
hmm, try other cheaper bundles and post them here
i really cant navigate through german(?) websites ;-; my brain is MHz now (mega hertz, mega hurts, get it? get it? no? k)
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609026
4 minutes ago, Castdeath97 said:
1-Why not skylake?
EVGA GTX 950 FTW
Intel i5 4460
ASUS Z97-P
Corsair CX450M
Seagate SSHD 1TB
Windows 10
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609028
BTW, the site is norwegian
https://www.komplett.no/product/793319/datautstyr/pc-i-deleroppgradering/pc-i-deler-intel/pc-i-deler-mini-itx-gamer#
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609035
EVGA GTX 950 FTW
Intel i5 4460
ASUS Z97-P
Corsair CX450M
Seagate SSHD 1TB
Windows 10
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609036
1 minute ago, Windows10Home said:
comments for this package
1) bad psu `-` you'll never find good psu in a package though, because they think we dont care about psu quality
2) o-kay cpu motherboard ram and gpu
3) still bad SSD `-`
also, you can get windows from other cheaper means
like G2A, subreddit microsoftsoftwareswap, kinguin etc etc
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609048
Should I go for a WD Blue 1TB 7200RPM or a Seagare Barracuda 1TB 7200RPM?
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609057
Just go for the cheaper one, most of the time it doesn't matter much.
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609060
How about this then:
Sapphire R9 380 4GB
i5 6400
CX450M
Carbide Spec-01
ASUS H110M-K D3
BallistiX Sport 2x4GB
Barracuda 1TB 7200Rpm
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609065
Sapphire R9 380 4GB
i5 6400
CX450M
Carbide Spec-01
ASUS H110M-K D3
Seems good. How much would it cost.
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609067
Without Windows... 7.153 NOK and I found Windows on Kinguin for 29.99€ That's 280 NOK!
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609070
So you still have some money lift to get a SSD and a i5 6500 I guess?
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609074
OMG. This may be the solution!
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609077
Is a HyperX Fury SSD 120GB good?
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609080
I heard it is, I guess so.
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609085
9 minutes ago, Castdeath97 said:
This is glitched. You didn't say this
Well, then I think this will be a good build!
Thanks for your help!
Windstriker 1.0
Old Laptop
HDD: 443GB
https://linustechtips.com/topic/583072-help-with-budget-build/#findComment-7609096
