Hello, I am currently living in Japan. I want to buy a gaming computer with a budget 1700$~
I am looking at alienware Area 51, origin PC millennium and Genesis, Digital storm Vanqush 5 and Bolt 3.
They ate pre build desktops and starts from 1600$~ with good specs. In future I want to upgrade them. I was thinking buying a gaming laptop, but the are so expensive, better get desktop with ability to upgrade in future,  then a laptop.
The second problem is I need to buy them outside if the Japan, because here they are so expensive.
I was looking who can do international shipping and only alienware on Amazon and Digital Storm do ship world wide.
I would like to hear your opinion , thank you !
https://linustechtips.com/topic/582913-need-help-with-pc/
You shouldn't go for Alienware, you're better off by building your own custom built PC and having the parts shipped to you.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/582913-need-help-with-pc/#findComment-7607683
Well I did try to build and it was like around 1400$~
But I don't really understand in it really well to do by my self, so I am thinking it will be better to get pre build with warenty and then up upgrade it. To build you need time and understand what you are doing, it will be east to pay 200$ more and get finished pc with warranty .
https://linustechtips.com/topic/582913-need-help-with-pc/#findComment-7609670
How about you show us the parts list you came up with for 1.4k? Maybe from there we can give you suggestions and what not.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/582913-need-help-with-pc/#findComment-7610158
1 hour ago, Denis6624 said:
Ok http://pcpartpicker.com/p/Lypj8d. This is my build
You might want to add an SSD, and maybe a cheaper case (well unless you really love this case a lot, then go ahead with it). Other than that, looks like a great build to me (though the colours don't really match lel).
Oh yes, you can get Windows for cheap on Reddit.
https://www.reddit.com/r/microsoftsoftwareswap/
https://linustechtips.com/topic/582913-need-help-with-pc/#findComment-7612497
Thank you, I really like to try and build it by my self, but I think I can break something. And to buy them and ship to Japan - that will be a problem, some things don't ship to Japan or shipping will cost more.
So I think it's better for me to buy an origin pc
https://linustechtips.com/topic/582913-need-help-with-pc/#findComment-7617086
Alright then, but you may want to choose other boutique PC builders, Origin PC tends to be a little more expensive. You can also check out the Maingear Vybe.
https://linustechtips.com/topic/582913-need-help-with-pc/#findComment-7617812
55 minutes ago, Denis6624 said:
Oh it's a nice looking pc, can you tell me about ? Like why do you recommend it and etc ?
Thank you!
Welp, to be frank I don't know much about it. I just went to their site and saw that that is a nice looking midtower machine for the starting base price lel.
https://linustechtips.com/topic/582913-need-help-with-pc/#findComment-7619929
