Hello all! Long time watcher, first time poster!
Anyway, I've started a new project which basically I'm going to be spraying my new build to have the appearance of the Asiimov skin from Counter Strike and I have started a blog page for it on my website which can be found here: http://tomhegarty.co.uk/projectasiimov/
TL;DR - I'm starting a new build while buying parts every month I get paid, and I'm looking for help and/ or suggestions for
  • Painting the Case itself
  • Theming the case/ hardware
  • suggestions on better hardware
My full new build can be found here: http://uk.pcpartpicker.com/p/d8kVt6
I've purchased the Case which is an Enthoo Evolv Itx, and 5 Noctua NF-F12 fans, so those are the things that will be staying the same.
I'm really looking for useful tips and suggestions and I couldn't think of anyone better for the job than you lovely people.
Thanks. :D
-Tom
https://linustechtips.com/topic/582640-project-asiimov/
I'll just pop in the suggestion of getting a better PSU. Corsair's RM series are overpriced for their quality - get a EVGA SuperNOVA 650 G2 instead. A GTX 980Ti won't need a 850W PSU unless you're SLI'ing (which is impossible for a Mini ITX build).
Good luck!
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/582640-project-asiimov/#findComment-7605154
For painting the case, just google asiimov template and use what you like the most. Just plan it out on the case then spray paint it with the blue tape thing to block the other places with different colors. Trust me bro, here's a few examples
https://linustechtips.com/topic/582640-project-asiimov/#findComment-7605182
7 minutes ago, Brennan_Price said:
Do you mean the writer Asimov?...
Cuz I got a load of things if you did him.
I dont play Counter strike so I dont know what ur talking about really.
He is talking about a famous white, orange and black paintjob for guns in the game.
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/582640-project-asiimov/#findComment-7605184
  Reveal hidden contents
Oh right, I can think of a few for that. In fact I think I've seen a few in halo 5 as weapons skins.
IT Manager working in the Education sector.
https://linustechtips.com/topic/582640-project-asiimov/#findComment-7605188
  Hide contents
That's actually super useful, Thank you so much! :D I've got a couple profiles of the case on Photoshop for some planning out, so this will really help.
https://linustechtips.com/topic/582640-project-asiimov/#findComment-7605214
2 minutes ago, Zeinone said:
Maybe take a look at the NZXT Kraken x61 also as a cooler due to more aesthetic reasons (the waterblock has an LED which would perhaps suit you nicely)
Thats really nice, but I'm concerned about the tubing coming out of the side of the block. Has it been used in any Itx systems? Because usually the ram slots on itx mobos are very close to the CPU socket.
https://linustechtips.com/topic/582640-project-asiimov/#findComment-7605244
Update on the rig!
Got my Noctua NF-F12's come today and the Phantek Fan Controller.
The controller is really nice and fits snug into the case, but it's risen a couple questions.
1. My fan headers are 4 pin but my controller is 3 pin, the 4 pins can fit but is this a problem?
2. Will it be fine plugging my upcoming closed-loop pump into the fan controller?
Thanks for the help so far all! :D
-Tom
https://linustechtips.com/topic/582640-project-asiimov/#findComment-7606025
