So I have a ThinkPad T430s with Windows 10 64bit and am having an odd problem thats driving me crazy.
Its intermittent but always happens when turning it on from sleep, The entire screen get a purple tint then over the time of about 5-7 seconds it returns to normal. Any ideas?
https://linustechtips.com/topic/582254-have-odd-issue-please-help/
still got warranty? because that sounds like a hardware issue.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
Just now, beaker15 said:
No, besides I WILL NOT send my product back to Lenovo again. Made that mistake once.
maybe install linux on a seperate partition. if the issue is there too you can be quite sure its hardware related
I don't have enough space on my SSD. I did find that if i go into color calibration and turn green down a lot it looks the same. You think it could be a color calibration glitch? I did color calibrate my screen once or twice in the past.
mhm its possible. did you try to refresh or reinstall windows?
1 minute ago, beaker15 said:
Not yet i will probably try over the weekend tomorrow.
maybe it will help. windows is just an unstable mess
2 hours ago, beaker15 said:
I'd use linux and all but theres to many things i like about Windows, like using my finger print reader
yeah it's the only thing really annyoing me about ubuntu gnome.
