Have my first gaming rag built. Have a haswell i7 4770k processor and want to overclock to about 4.2 with a water cooling kit or a air cooling kit? Dont know need help dnt have the money for custom water loops yet but need a cpu cooling asap. Whats the best to cool my haswell for 4.2. Maybe something like Corsair Hydro H100i? thanks
https://linustechtips.com/topic/58225-haswell-4770k-cooling/
you should be good even with a hyper 212 evo
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/58225-haswell-4770k-cooling/#findComment-788451
Any high end air or water cooler will keep a 4770k cool. But a majority of the heat depends on how well your chip can overclock. Either a Noctua NH-D14 or Corsair H100i for high end cooling or even a Cooler Master Hyper 212 Evo is really good cooler.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/58225-haswell-4770k-cooling/#findComment-788464
H100i is if you're shooting for 4.5-4.6 ghz minimum. A Hyper 212 Evo would be plenty for you. It's cheap and a great value cooler.
https://linustechtips.com/topic/58225-haswell-4770k-cooling/#findComment-788486
Hands down..........h100i
What's a "Sortable" temperature?
https://linustechtips.com/topic/58225-haswell-4770k-cooling/#findComment-788987
Guys, It all comes down to the silicon lottery.  Don't target a clock speed.  Figure out what your chip can do without pushing voltage too high.  Follow the guidelines in this video.  It was made for Ivy Bridge but the concepts carry over to pretty much any platform that has chips with unlocked multipliers.
OC3D 1155 Overclocking Guide:    http://www.youtube.com/watch?v=mBEeXajbG2o
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
https://linustechtips.com/topic/58225-haswell-4770k-cooling/#findComment-790636
Corsair H100i or the H110 (however it does not fit in all cases). These are your best options. Stress test with Aida64. Your temps should not exceed 80C.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/58225-haswell-4770k-cooling/#findComment-792050
No I was just wondering what temperature should I never let it go past
Yeah, like Analog said, "Your temps should not exceed 80C."
That's damn Hot. That's 176 Degrees Fahrenheit!
Although, I believe Intel's limit is 90C(194 Fahrenheit), before it shuts itself down.
https://linustechtips.com/topic/58225-haswell-4770k-cooling/#findComment-792170
for benchmarking or stress testing i use an 85° cut-off. if you are looking for a bonsai
run the 90° for validation and then down-clock for 24/7 ops.
for 24/7 ops temperature with real-world apps i try to keep it under 70°.
airdeano
https://linustechtips.com/topic/58225-haswell-4770k-cooling/#findComment-792312
