need help with psu
Go to solution Solved by VinsinityKT,
EVGA SuperNova G2
Hi!
I know it is a common question but i really need help. I watched on youtube videos what psu to choose and I get confused. If anyone can tell me good modular psu for my configuration I would be grateful. And later wanted to add corsair hydro h100 and overclock the cpu.
Amd fx8320
Gtx 960
Asus 970 gaming pro/aura mobo
2x 8gb ddr3
1x ssd
1x hdd
5x 120mm fan
https://linustechtips.com/topic/582155-need-help-with-psu/
EVGA SuperNova G2
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
https://linustechtips.com/topic/582155-need-help-with-psu/#findComment-7600176
Did you get these parts yet or not? If not what is your full budget and location?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/582155-need-help-with-psu/#findComment-7600198
1 hour ago, vex_dm said:
Everything is ordered except psu and ssd. I got about 100$ for psu and I'm from Croatia.
Look around here to see what you can find
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
https://linustechtips.com/topic/582155-need-help-with-psu/#findComment-7600452
There's more to life than the EVGA G2 guys, gosh.
If the EVGA GQ/GS/B2 save you money OP then get one of them.
https://linustechtips.com/topic/582155-need-help-with-psu/#findComment-7601724
10 hours ago, vex_dm said:
Do you think that Corsair CX600M do the work or must be stronger psu.
No it isn't, it's not as good as any of the suggested PSU above.
https://linustechtips.com/topic/582155-need-help-with-psu/#findComment-7604816
