NZXT S340 Case Fans
ppppppp
The layout of the S340 goes like this: 1top(120/140mm), 1back(120mm/140mm) , 2 front fans(120mm/140mm). It comes with 2 120mm fans at the back and top.
1.What should i fill my front 2 slots with, 2x140mm, 2x120mm or maybe 1x140mm?
2.Can anyone recommend any nice looking, inexpensive, preferably red(Non LED) case fans? Also Black is Ok.
3. I want extra case fans but are they completely necessary? If they say cost £20 all together i could use that and get a MSI 380 or a XFX 380x.
I have been using the stock fans for quite some time now. If you're putting your pc on your desk I strongly recommend to either get a fan controller or new fans, because the fans are very loud at full speed. They do perform well, though.
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
The stock fans will work, but I find the S340 has excellent airflow if you put 2 140mm fans in the front and use the stock fans as exhaust.
Oh, but i would just plug it into my mobo and adjust it.
Any you recommend?
They have got 3-pin connectors
Project Pluto
They can still connect to 4pin connectors, cant they?
Since you are at a tight budget, I suggest just using the stock case fans as per results from the videos (especially the first one) above and getting the 380X or higher if possible.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
Wow very useful!! Thanks
Should i keep the fans where they are or move one to the front?
