I need help getting my wii u, as well as my pc to output audio through my monitor to my headset,
I am using hdmi from the wii u and a standard 3.5mm from my pc.
I am using:
  • acer g257hu monitor:
                                          http://www.amazon.com/Acer-G257HU-smidpx-25-Inch-Widescreen/dp/B00QS0AKVK
  • wii u:
                                         http://www.amazon.com/Nintendo-Wii-Console-Black-Deluxe-U/dp/B009AGXH64/ref=sr_1_5?s=videogames&ie=UTF8&qid=1460585574&sr=1-5&keywords=wii+u
  • audio technica ATH-M50x:
                                          http://www.amazon.com/Audio-Technica-ATH-M50x-Professional-Monitor-Headphones/dp/B00HVLUR86/ref=sr_1_1?s=videogames&ie=UTF8&qid=1460585657&sr=8-1&keywords=ATH-M50x
https://linustechtips.com/topic/581463-need-help-2-audio-sources-one-output-how/
There can only be one ~ Christopher Lambert
 CPU: Intel Core i5 6600K  Motherboard: Asus Z170-A  CPU Cooler: Corsair H110i GT  GPUGigabyte GTX 980 Xtreme  RAM:2x8gb HyperX Fury  SSD: 120gb A-Data  HDD: 1Tb WD Blue 7200RPM - 750gb Hitachi 2.5" HDD  PSU: EVGA SuperNova G1 650W  Case: Phanteks Enthoo Evolv ATX  Monitor: 27" AOC LED IPS x 2  Keyboard: Corsair Strafe RGB Silent  Mouse: Corsair Scimitar RGB
 HeadsetLogitech G430
1 minute ago, bluerubydragon said:
are you sure =(
No but it's not every day you get to quote highlander... sadly I'm an audio noob
You could put the TV audio  (from Wii U) from the headphone jack into your line in port on your pc. Then you can control both the TV volume and the Wii u volume on your pc.
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
yah thats what a figured out, thanks for the help anyway.
