Hey guys so i'm currently working on a project, which you can find here: project aqua, I would like to know what would be a cool coolant for my water cooling system. If it could be under 15 and be blue that would be great. I was looking at Mayhem;s aurora dye set and that looked pretty good if you guys could give me reviews on that, that would be great as well!
https://linustechtips.com/topic/580412-coolant-for-project/
I would recommend something like Mayhems Pastel or X1 if you want to use the Aurora series the Aurora 2 series is the best choice as it is designed for longer term use, but it does require a compatible watercooling blocks and components to prevent clogging as it has a larger particles.
https://linustechtips.com/topic/580412-coolant-for-project/#findComment-7582662
1 minute ago, chek mix said:
@W-L Which one out of the two you recommended is less cloggy? If that made sense
The clear X1 series is probably going to be the lesser of the two as it has no nanoparticles like the pastel and the larger shimmery ones in the Aurora 2 stuff, however if the loop it very clean and setup correctly it shouldn't clog.
https://linustechtips.com/topic/580412-coolant-for-project/#findComment-7582686
@W-L For the watercooling system i'll be using this kit http://www.performance-pcs.com/xspc-raystorm-extreme-universal-cpu-watercooling-kit-w-ex120-radiator-750-pump-res.html do you know if aurora will go without clogging?
They have a compatibility list here for all the components but the XSPC bay res don't work with the aurora series however:
https://mayhems.co.uk/mayhems-aurora-guide/
https://linustechtips.com/topic/580412-coolant-for-project/#findComment-7582718
