So, this would be the build I`m about to purchase, which should be used mostly for gaming and Photoshop/CAD: http://pcpartpicker.com/user/shomy993/saved/2q7h
i7 4770k
Asus GTX780 DirectCu2 x 2
Vengeance Pro 2133MHz(CL9) 4x4Gb
Maximus VI Formula
840 Pro 256Gb x 2
WD Blue 1Tb x 2 (painted black)
H100i (Corsair SP fans, push-pull)
Corsair Air 540 (3x120mm, 1x140mm)
AX860i PSU
Corsair K70 keyboard
Corsair M40 mouse
Samsung S27A850D display
Is it legit or should I make some changes?
https://linustechtips.com/topic/58036-ultimate-gamingworkstation/
i would go single titan, because it has workstation features, and has a hell of a kick in gameing performance, and bragging rights. street creds. swag.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/58036-ultimate-gamingworkstation/#findComment-785728
Well, I am going for SLI due to high resolution I`ll use, and 780 has top performance in that segment, atm...
https://linustechtips.com/topic/58036-ultimate-gamingworkstation/#findComment-785735
do you think the titan will not be good enough? i know people with that resolutions that run a 670 who run skyrim with a ton of mods @ 50 fps. and 6 gb vram
https://linustechtips.com/topic/58036-ultimate-gamingworkstation/#findComment-785749
I guess it would be enough, but i plan on using this configuration as long as possible, so will 2 Gtx780 outlast Titan?
https://linustechtips.com/topic/58036-ultimate-gamingworkstation/#findComment-785762
you can upgrade to dual titan in the future, but a 780 sli will perform better now, but do not have the workstation options
https://linustechtips.com/topic/58036-ultimate-gamingworkstation/#findComment-785768
