4 hours ago, duckwithanokhat said:
What length of cablemod LED strips would I need to cover the perimeter of the big window in the phanteks enthoo pro?
Well it depends on how your trying to light your case, usually it's best to have two strips either top and bottom or to either side of the case to evenly cast light out towards the components. If you wanted however to perimeter light the window you are most likely looking at two 60cm strips.
https://linustechtips.com/topic/580071-led-strip-length-needed/#findComment-7580290
