I need help identifying what Type of Ram this is. The board is a decade old Asus M2N-SLI Deluxe and I've been told it uses DDR2 Ram, but I think my idiot brother bought DDR3 Ram and stuck it on and broke the damn thing.
All I can identify is that it is manufactured by Kingston, that's all. Maybe  PC sage can tell just by looking at it?
Ps, would I be able to stick any more RAM on, as there's a lot of unoccupied real estate on this board and I kind of want to see what it can be pushed to?
https://linustechtips.com/topic/579831-need-help-identifying-ram/
Thread moved to CPUs, Motherboards, and Memory.
It's DDR2.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134045
Kingston 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model KVR667D2N5/1G
its 512mb  vs 1gb in the link
http://www.crucial.com/usa/en/compatible-upgrade-for/ASUS/m2n-sli-deluxe
if i post a link to amazon try to use the LTT affiliate code to help the channel http://www.amazon.com/?_encoding=UTF8&camp=1789&creative=390957&linkCode=ur2&tag=linustechtips-20
12 minutes ago, Supercian411 said:
how can you even put ddr3 on a ddr2 mobo
I'm also wondering; they aren't backwards compatible, and the notch has been moved to prevent insertion into older slots.
Have a look at this to help you.
EDIT: It indeed is a DDR2 RAM
(\__/)
(='.'=) This is Bunny. Copy Bunny into your signature to
(")_(") help him on his way to world domination.
to be fair this is a thing
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
You have to try really hard to force DDR3 onto a DDR2 board.
Googling the motherboard reveals that it would be DDR2 in it currently. Also the voltage spec does say 1.8V. Which would indicate stock DDR2 voltage.
