I just built a new computer and I am looking for a cpu cooler for my AMD FX-8350 8-core. I may overclock it but i want a good cooler.
CPU: Ryzen 5 2600 GPU: MSI RTX 2070 Gaming Z  RAM: 16GB DDR4-3200 MOTHERBOARD: ASUS B450-F Strix
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/
8 minutes ago, Schony125 said:
water or air?
Preferably Air because its way cheaper.
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/#findComment-7575621
5 minutes ago, i respawn. said:
depends on your budget.the more you pay the more horspower you can get for your cpu.
Under $40
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/#findComment-7575638
well for such an hot chip and if you plan to overclock its better water even if I prefer air coolers
I dont know the pricing in the us but I think it would be better to get a mid range 240mm AIO water coller
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/#findComment-7575647
3 minutes ago, i respawn. said:
These are your options:
http://pcpartpicker.com/parts/cpu-cooler/#X=0,4081
I recommend the Hyper 212 evo. reliable and trusted.
Thats what I was thinking too. Thanks
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/#findComment-7575673
1 hour ago, Dudegt said:
Under $40
IMO, you're not going to get much of an overclock on an 8350 with any sub-$40 cooler. I'd just go with the stock cooler, no overclock, until you can afford either a high-end air cooler or a decent 240mm AIO. A 212 EVO can't keep up with the heat that CPU would generate at higher overclocks.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/#findComment-7576144
Thank You
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/#findComment-7577160
I am considering the corsair hydroseries is that a good idea?
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/#findComment-7577184
https://linustechtips.com/topic/579689-i-need-a-cpu-cooler/#findComment-7577257
