New build. Help
Go to solution Solved by No,
Yeah, just go for a 980ti
Hey,
So i would like ur opinion. I want to Update/Expanded my build. Tips are welcome. I want to SLI on my GPU. and get the max out of it. Would this work ?
Old Build
  • CPUINTEL Core i7 3770K
  • MotherboardGigabyte z77x-d3h
  • RAM16 RAM Kingston DDR 3
  • GPUGIGA-BYTE GeForce GTX 970 OC Windforce
  • CaseNZXT Phantom white
  • StorageSamsung SSD 250GB/ Green WD 1 TB
  • PSUCORSAIR CX (750 watt, atx)
  • Display(s)ACER PREDATOR X34
  • KeyboardRazer Death Stalker Chroma
  • MouseRazer Abyssus 1800
  • SoundRazer Kraken 7.1 Chroma
  • Operating SystemWindows 10
Updated Build
  • CPUINTEL Core i7 6700K
  • MotherboardGigabyte GA-Z7170X-Gaming 7
  • RAM16 RAM G.Skill Ripjaws DDR4
  • GPU2X GIGA-BYTE GeForce GTX 970 OC Windforce
Thx Alot , Greetz iDreamzZ-
https://linustechtips.com/topic/579600-new-build-help/
It would work but I'd avoid SLI altogether since it can potentially give you a headache with the problems associated with it (microstuttering, games not utilising it properly).
Either sell the 970 and get a 980Ti or wait for Pascal/Polaris (I'd go for the latter).
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/579600-new-build-help/#findComment-7574816
Tough choice, though for now if I was in your shoes I would sell the 970, buy a 980ti and keep the 3770k.  It's generally better to have a real good single gpu than 2 lessor cards...
To get the most for your money anyway, upgrading from a 3770k/ddr3 to a 6700k/ddr4 is a lot of wasted dollars.
my work in progress
i5 6600k  //  16gb g.skill ddr4 3000  //  evga gtx 980
custom water loop
https://linustechtips.com/topic/579600-new-build-help/#findComment-7574819
It can potentially be a little quicker, but the problem is that in games that do not support sli, it's not going to be.  And there's a lot of scenarios where your 2nd gpu is just going to be wasted.
my work in progress
custom water loop
https://linustechtips.com/topic/579600-new-build-help/#findComment-7575010
Thx alot for helping u convince me.
But witch one should i buy.
Giga-byte Nvidia Geforce GTX 980 Ti Xtreme OC WaterForce
Giga-byte Nvidia Geforce GTX 980 Ti Xtreme OC Windforce 6gb grafische kaart
Giga-byte Nvidia Geforce GTX 980 Ti N98TG1 Gaming
:D
https://linustechtips.com/topic/579600-new-build-help/#findComment-7585328
