After a few minutes of playing battlefield 4, both my monitors go black screen, sometimes I can still hear sound, and they stay black untill I do a full shutdown.
So far i've played CSGO, Minecraft, BO3, and none of them had the problem.
I've tried new drivers, old drivers, uninstalling PhysX driver, and nothing worked so far.
Any insight on the problem will be appericated.
https://linustechtips.com/topic/579579-gtx-970-bf4-blackscreen-help/
If it only occurs in BF4 and no other game (also try a few stress tests like unigine valley/heaven and furmark and report the temperatures, voltages etc.) it's probably a software problem and has nothing to do with your graphics card.
You said you tried re-installing drivers.. other than re-installing BF4 I have no idea right now unfortunately..
Edit:
The maximum temperature of the gtx 970 is 98°C as stated by nVidia: http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-970/specifications
so you're definitely fine. Which particular model (manufacturer) do you have? Also what are the other hardware components of your system? If you're not sure you can download a tool like "hwinfo". It might be that your Power Supply causes the crash. But i fell like then it should also happen in synthetic benchmarks /stress tests. Because a program like furmark is much more demanding for a gpu than a typical pc game.
 Intel Core i7 4790K || G.Skill 16GB DDR3 || MSI GTX 970 Gaming 4G || Fractal Design Define R5 || Asus Gryphon Z97 || EVGA SuperNOVA 750G2 || Crucial MX100 256GB || Noctua NH-D15
Edit:
My PSU is 700W, and I have i7 4770 and msi z87-g45, from what i've read it doesnt seem like the power supply should be using so much power.
I will try first thing tomorrow some benchmarks and check the results.
https://gyazo.com/7d486bc7c763d4595e003a147c286f3b - hwinfo
Thanks for the help.
41 minutes ago, Schony125 said:
finally, this is what you get when you get out of your game works zone and play 1 of the games that is favoring amd instead of the 1000 games favoring nvidia.
Its a joke ;P
try reinstalling bf4 should fix the issue
reinstalling overnight, will update when I wake up.
Just checked again after reinstalling, crashed again.
Temp was 60-65 degrees (cooler day), and power consumption was between 90%-102% (wtf?). all according to gpu-z.
i'm assuming the problem is power, I have a 700watts psu.
Is there anything to do without buying a new psu?
Edit:
Hi, just ran unigine valley, and same thing happened, power 90%+++ and gpu heat ~65 and blackscreened.
Edit : Just played blacksops3, it had the same tempature and same power consumption but it only blackscreened after hour/two (not sure).
Ok. Well if you still have warranty I'd contact the support and tell them about the crashes (and that you didn't overclock). If it crashes in different applications the graphics card might be defective somehow. Still it could be something else but I have no clue..
Good luck!
