So I would like my sec keyboard switch my scenes in my obs so I'm trying to use his thing so I took from. Here is my code could someone tell me  what I'm doing wrong?
#NoEnv  ; Recommended for performance and compatibility with future AutoHotkey releases.
; #Warn  ; Enable warnings to assist with detecting common errors.
SendMode Input  ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir%  ; Ensures a consistent starting directory.
#SingleInstance force ;only one instance of this script may run at a time!
#IfWinActive ahk_exe obs32.exe ;---EVERYTHING BELOW THIS LINE WILL ONLY WORK INSIDE OBS!
#IfWinNotActive ahk_exe obs32.exe  ;
numpad5::
FileRead, key, C:\Users\Daniel\Documents\keypressed.txt
If(key = T)
Send ^!+T
return
numpad1::
If(key = Z)
Send ^!+Z
return
numpad2::
If(key = X)
Send ^!+X
return
numpad3::
If(key = C)
Send ^!+C
return
numpad9::
If(key = S)
Send ^!S
return
https://linustechtips.com/topic/579268-ok-now-i-need-help/
Well I haven't used AutoHotKey before but looking at that code I'm assuming the semicolon is for comments and if that is correct you have commented out a line which a comment says that it gives feedback on errors so my suggestion would be to uncomment that line and see what error messages you get and go from there :)
https://linustechtips.com/topic/579268-ok-now-i-need-help/#findComment-7602655
Also another thing I noticed is:
numpad9::
If(key = S)
Send ^!S
return
The send there is different to the send on others which has a + in it so I don't know if that makes any difference but probs does.
https://linustechtips.com/topic/579268-ok-now-i-need-help/#findComment-7602663
