TF2 Not running on Virtual Machine
Hello everyone, I wanted to try and run TF2 on a VM using Virtual Box, I have a windows 10 VM set up on my host PC. The host pc is running windows 10.
I have TF2 installed, as soon as I try to run the game a black window pops up for a split second then goes away straight away. Then it acts as if I never launched the game. No background tasks about TF2 in Task manager.
I have verified integrity of game files and that hasn't helped.
I have deleted the CFG folder and everything in the custom folder, verified intergrity of game cache and it STILL doesn't work, this time not even showing a black box.
I have 4 cores and 4 GB RAM and 256 MB of video card RAM allocated to the Virtual Machine. Still nothing.
HERE IS A GIF
_c6c0f2a626f8935f1afdd3f57ca9b464-gif.gi
Please, any help is appreciated!
Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($484.00 @ Umart)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($179.00 @ CPL Online)
Motherboard: Asus Z170-AR ATX LGA1151 Motherboard  ($228.00 @ CPL Online)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($105.00 @ CPL Online)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($126.00 @ CPL Online)
Storage: Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card  ($719.00 @ CPL Online)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($179.00 @ Umart)
Power Supply: Corsair CSM 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($155.00 @ IJK)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($19.00 @ CPL Online)
Other: Windows 10 ($100.00)
Total: $2294.00
Generated by PCPartPicker 2016-04-09 21:54 AEST+1000
CPU: i7-6700K 4.7GHz GPU: GTX 980 STRIX 1337MHz CPU Cooler: H110i GTX AIO |
 Motherboard: Asus Z170-AR | Case: NZXT H440 White PSU: CS750W |
 PCPartPicker Link: http://au.pcpartpicker.com/p/43BkVn
https://linustechtips.com/topic/579061-tf2-not-running-on-virtual-machine/
May I ask why are you attempting to run Team Fortress 2 in a virtual machine?
Why not run it directly on your computer?
Virtual Machines tend to have a hard time running games even though you have given it some good specs.
If your still trying to run it, make sure VT/d is enabled in your BIOS and that virtualbox is using it.
Edited by mclarence
CPU: Intel Core i7 4770 @ 3.4 ghz (Turbo 3.9ghz) RAM: Trancsend 2x 8gb 1600mhz DDR3 (16GB) GPU: Gigabyte Nvidia Geforce GTX 970 Case: Cooler Master HAF922 Storage: Sandisk Ultra II 120GB Solid State Drive, Seagate Barracuda 1TB Hard Drive PSU: Cooler Master CX750 750w Power Supply.
Keyboard: Logitech G310 Mechanical Compact Keyboard Mouse: Logitech G302 Gaming Mouse Displays: 3 Monitors Operating System: Windows 10 Home
In order to play games you need a VM that provides you with full support of DirectX and OpenGL, or the appropriate version of the game, and sufficient memory. If memory serves correct, VMWare only support partially DirectX9 with up to 256MB of memory, assuming you configure it to use the max settings.
Because I want to level my stranges up by idling my other account and killing it over again. Yes, pathetic I know. But I want to try it see if it works.
Also, how do I enable VT/d?
I don't care about the graphics, I would run it in command line mode if I knew how to set it up properly. I want to set it to minimum settings but I have no clue how to.
First, verify if its already enabled by going into task manager, then into the performance tab and check if the  "Virtualization" part says enabled.
If it says "Disabled", head into your BIOS and head into advanced settings and look for an option called VT/d or "Virtulization Techonology" or something similar.
Also in virtualbox, tick "Enable 3D Acceleration" in the virtual machines settings, under display.
And bump up the video memory.
It is enabled :D
If it is still not running, try and run the game in ubuntu linux.
video memory is maxed and 3d and 2d acceleration are both ticked.
Guest
