Side panel not coming off
Go to solution Solved by W-L,
43 minutes ago, derpyapple said:
http://imgur.com/a/CyOYJ Here are the pictures you ordered (just inside) I left a spagghetti monster while installing some things like the psu and hdd @DevilishBooster
If all the screws are out push down on the edges of the side panel where the clips are holding the panel and give it a good old yank to slide it back.
Hi, I have a Corsair 100R (windowed case) the side panel behind the mobo tray is not coming off
Have you guys had any issues with this at all?
                             Current PC Specs
                       GPU: 750ti CPU: AMD FX-6300 PSU: EVGA 500W Case: Corsair Carbide Series Windowed 100R Mobo: Gigabyte GA-970A-DS3P
https://linustechtips.com/topic/578613-side-panel-not-coming-off/
are your cables pinned under it super tight?
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
I haven't built it yet. gonna be building later and I want the side panel off
                             Current PC Specs
..... Did you losen the thumbscrews.....?
(I have to ask)
Or does it have a retention clip on the back?
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
are you sure you've got the screws out?
sometimes things are factory tight and you just need to keep at it.
(I have to ask)
yes i loosened the thumbscrews
                             Current PC Specs
Yes im sure
                             Current PC Specs
Are you able to post some pictures? I'm a visual person so I can usually help better if I can see what is actually being worked on.
END OF LINE
I guess my phone is dead so give me a bit of time
                             Current PC Specs
                             Current PC Specs
