Good fan controller and fans?
Solved by Moonzy,
maybe a PWM fan splitter/hub will do you better?
since they can be software controlled
just make sure your motherboard header supports pwm for the hub to work
or supports the wattage that your fans need if you opt for the splitter, can check the motherboard manual for this
blue accents fan? corsair AF/SP 120? with the blue rings
Featured Topics
ImMiles ·
Posted in New Builds and Planning2 -
D-pacman ·
4
generic000 ·
Posted in Graphics Cards10 -
Cringe_Master245 ·
Posted in CPUs, Motherboards, and Memory1 -
Rideonbrother ·
Posted in New Builds and Planning1 -
3
play_circle_filled
Latest From ShortCircuit:
I'm a Huge Sucker for a Cool Gimmick - Epomaker DynaTab 75X & DynaTab 75
play_circle_filled
Latest From Mac Address:
The Apple Vision Pro Leaves a Mark (but not the right kind)
