I need help
Go to solution Solved by Sentryy,
1 minute ago, Matthew_innes said:
That is good, you could go with the one I just linked to you. It has an SSD, Motherboard, Core i7 6700k, and 16gb of DDR4 and just sell the 8GB DDR3, Motherboard, and the CPU on ebay or something.
Hi my name is Matthew and i am looking to upgrade my CPU,mobo,CPU cooler and ram.
i have £500 budget that about $700 us. I am looking for a CPU that can play games and stream
the games i play are arma 3 , the division , rainbow six and fallout 4.
i need the mobo to have and m.2 slot and 2 way SLI capable.
and if you pick any aio the rad has to be a dual 120 or singel 120
If any can help it would be appreciate thanks matthew:)
https://linustechtips.com/topic/578280-i-need-help/
What parts do you currently have (and their brand and model)?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/578280-i-need-help/#findComment-7561655
Just now, Matthew_innes said:
yeah i have room for a tower cooler
So then what's your current case?
https://linustechtips.com/topic/578280-i-need-help/#findComment-7561680
Keep the RAM and get A 8gb stick for 30$.
Next get a core i5 4790k,
And a z97-a ASUS board to accompany it.
Get a cooler master Hyper 212 EVO.
also you might want to upgrade your power supply for SLI as we don't know what it is.
I like to kill hardware. In 2016 alone I have killed 20 Xeon 5160, and 10+ Pentium 4.
https://linustechtips.com/topic/578280-i-need-help/#findComment-7561722
2 minutes ago, Matthew_innes said:
I'd recommend upgrading your CPU to an i5 (maybe 4690k), you'd have to get a new MOBO too, but you can use the same ram (its fine)
https://linustechtips.com/topic/578280-i-need-help/#findComment-7561741
5 minutes ago, Matthew_innes said:
Get everything I told you to, except the cooler your current one is fine. If you can, get this this also includes an SSD because hard drives are slow. http://pcpartpicker.com/p/s7NWMp Just install windows on the SSD along with a few programs.
https://linustechtips.com/topic/578280-i-need-help/#findComment-7561772
You might want to also get an SSD, but that's good.
https://linustechtips.com/topic/578280-i-need-help/#findComment-7561777
https://linustechtips.com/topic/578280-i-need-help/#findComment-7561780
1 hour ago, Matthew_innes said:
i have a h440 case and 8Gb of ddr3
Looks like you can fit large radiators into that case so here
Also 8gbs of DDR4 is pretty cheap, so you might as well jump to skylake for the extra 5% performance, maybe even grab a 16gb kit so you never have to worry about it, that would leave about 50 pounds more for the motherboard or something
PCPartPicker part list: http://uk.pcpartpicker.com/p/M4xtXL
Price breakdown by merchant: http://uk.pcpartpicker.com/p/M4xtXL/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£200.99 @ Ebuyer)
CPU Cooler: Cooler Master Nepton 280L 122.5 CFM Liquid CPU Cooler  (£99.99 @ Amazon UK)
Motherboard: ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard  (£92.13 @ Ebuyer)
Memory: Kingston 8GB (1 x 8GB) DDR4-2133 Memory  (£25.12 @ Amazon UK)
Total: £418.23
Generated by PCPartPicker 2016-04-07 23:49 BST+0100
It's not that your CPU is horrible exactly, it's more that it isn't OC'd to like 4.5ghz, but yes in CPU intensive games like ARMA or Total War an AMD CPU's weak Per core performance is going to hold you back.
But ya, start there, maybe spend a bit more on the motherboard for a bit nicer one for overclocking
also if you want SLI you need an SLI motherboard because nvidia hates freedom I guess. But going for 2 GPUs is almost never worth it anyways.
Did you already list your power supply?
https://linustechtips.com/topic/578280-i-need-help/#findComment-7561949
