I just assembled my new Gaming rig which has:
Intel Core i7 6700K CPU
ASUS Z170-A Motherboard
Corsair RM750
HDD with Windows 10
After CORRECT installation and testing, the PC ran perfect for a month. During me running a program the computer froze then I shut it off then I hit the power button and no ASUS logo shows up or any boot up splash screen. This appears to be a no-post situation. In the board, I see a red CPU error light from the bottom of the CPU area and after manual shutdown some lights stay on. I removed the psu cable after flipping the switch to "OFF". I sent ASUS the motherboard for repairs and they said that the board was fine and even tested so I suspect it could only be the CPU.
I have two videos of what happens. The second is a second part of the first video.
20160405_214534.mp4
20160405_215418.mp4
https://linustechtips.com/topic/577464-red-cpu-light-gaming-pc-is-not-working/
Are u able to try out another psu / cpu?
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
4 hours ago, VulcanAndroid said:
Have you tried booting the system since you received it back from Asus? Otherwise try a difference CPU like Rodniz suggested if possible.
I assembled everything back together like I had it before even started it up and the same issue happened. It appears to be a no-post situation where nothing shows at boot up and a red cpu light (meaning theres a cpu related issue) that shows up after I restart the PC and still no post.
