Controller detection problem
Go to solution Solved by SaladFingers,
45 minutes ago, I am an SSD said:
Has anyone had problems in getting their controllers ( cheaper 3rd party ones) to work with certain games? In my case, the games straight up refuses to load if a controller is connected, and then does not respond...i have to alt+tab and close it manually....
Yes. Some games are stupidly made to only work with the real xbox 360 controller even if your gamepad is xinput. You either need to emulate it (x360ce) if it doesn't work, or re-map the buttons if they are messed up (xpadder). The re-mapping method usually is needed for games of the pre-xinput era (dinput) and usually the triggers won't work.
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
https://linustechtips.com/topic/577099-controller-detection-problem/
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
Thanks for the links....i just started using controllers...hence the problems...
Yeah it's a pain.. And microsoft keeps messing with the drivers for even their own controllers breaking things...
~ Specs bellow ~
